TxGearhead wrote:
Hmmmm….I'm not sure about those bolts pulling against the camper siding. Is it filon or aluminum?
I just wrap a plastic coated cable with hooks on both ends around mine.
One screw is into the square aluminum tubing used for the frame. The other screw is through the Filon, wood, and into the sheet metal box of the generator compartment. I sure hope they don't pull out.
I used to use bungees to hold up the steps but it looked kinda Okie.
Where did you hook your cable on the camper?
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
