Scissor step latch
Geewizard
I wanted a way to keep my permanently-mounted scissor steps up out of the way of my motorcycle trailer tongue while traveling.
I came up with this solution:
The rubber stopper bumpers keep the steps from damaging the camper.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
4 REPLIES 4
Geewizard
TxGearhead wrote:
Hmmmmโ€ฆ.I'm not sure about those bolts pulling against the camper siding. Is it filon or aluminum?
I just wrap a plastic coated cable with hooks on both ends around mine.
One screw is into the square aluminum tubing used for the frame. The other screw is through the Filon, wood, and into the sheet metal box of the generator compartment. I sure hope they don't pull out.
I used to use bungees to hold up the steps but it looked kinda Okie.
Where did you hook your cable on the camper?
ardvark
Nice sanitary look! ๐Ÿ™‚
TxGearhead
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
tattoobob
Great Idea
2005 Ford F350 SRW 4x4
2000 Lance 1010
