Screws being pulled out on Awning
scarecrow56
On my Apex 269RBSS there are two vertical channels bolted to the RV. Bolted on top, screws on bottom and 2 screws about midway up. The 2 screws midway are being pulled out of the wall when the awning is fully retracted (all the way in). Also it looks like while doing that it bows the vertical channel out in the middle. As soon as the awning is let out even a little, the channel pops back onto the wall. This is happening on both sides, left and right. Anyone ever see something like this before? Is this a common thing or am I just lucky? Thanks
Chillin' in the sun, Palm Bay, Fl.
17 REPLIES 17
Ava
Try riveting those areas. I just installed awnings over my windows and they came with screws and rivets for walls with no backing
Huntindog
Is this a new TT?
It sounds like there may not be a backer board/plate for the screws to bite into. Could be that this was an aftermarket installation, or the factory forgot to install them..... Or maybe the screws just need tightening... Though I am skeptical on this, as none of my awnings have ever loosened up.
I am hoping for you that this is a new TT, under warranty, as a missing backer board is a pretty serious issue.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
ScottG
Have you tried just tightening them?
