Short Double Bunk TT
tkoden
We are looking for a short double bunk trailer like the Passport 2400 but the issue is that we need a walk around full size queen. I am 6'-7" and most of the trailers have a wall right at the foot of the bed. We also need an outside kitchen. Any suggestions?
2 REPLIES 2
Dannyabear1
Flagstaff makes a 25' bunkhouse - 25bhs- that has a Murphy bed with no wall at your feet; no outside kitchen tho
SoundGuy
tkoden wrote:
... but the issue is that we need a walk around full size queen. I am 6'-7" ...
Think about this for more than just a nanosecond and it should be obvious this "requirement" alone makes no sense. :R The majority of so-called "queen size" walk around beds in trailers are actually "short queen", meaning ~ 74" long, which isn't even long enough for those of us just 5' 10" tall. Some manufacturers do install a true queen bed measuring 80" long and while that certainly solves the problem for those of us no taller than 6' it certainly doesn't solve it for basketball players like yourself. :R Although disdained by many your better solution, because you are so tall, is a bed that runs laterally across the width of the trailer and therefore by definition can be much longer than a traditional queen walk around bed.
You also need to define what you mean by a "short" double bunk TT ... for some that would mean under 20' coupler to bumper, for others anything less than 30' would be short. No wonder you haven't had any responses to your query. :R
2012 Silverado 1500 Crew Cab
