siding
joe_puma
On a recent trip to Smoky Mountains, I noticed that the ribbed siding on my 10 year old Puma 28' camper was bowing out, like the wind from towing was pushing it out. I went to Ace and got some stainless screws and caps and silicone and added a couple screws to hold it in. Looked better coming home, but slight bow a little lower. Anyone ever have this type of issue, and how did you fix it? Any thoughts?
2 REPLIES 2
Huntindog
Yes. On my 2001 Wilderness. It was the leading edge of the wall on the Passenger side. I used duct tape to get home. Then I removed the siding from that area. Basically from the door to the front of the TT. What I found was that very little holds that siding on. One small staple every 16" or so. The walls were 2x2s with totally random lengths between them. I installed horizontal 2x2s between the vertical ones so that I could staple the siding every 2". The most time consuming part was that every 2x2 was a different length. It really wasn't that bad of a job. In fact I did the other side too as a prevenative measure. Never had anymore trouble after that.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
ScottG
I wouldn't worry too much about it. It's probably not getting air under it as much as the air moving over the outside is causing a low pressure area resulting in "lift" like an airplane wing.
Also, my last TT did that just because the insulation was pushing it outward a bit. But it was like that just sitting there.
I would make sure there's no cracks in the caulking anyplace but otherwise it should be OK.
