May-05-2017 04:14 AM
May-06-2017 10:24 AM
May-05-2017 11:16 AM
Hoffmac wrote:
The battery is the same one that is in my car. I just use jumper cables when I need to move it in and out and it has worked perfectly fine
May-05-2017 10:16 AM
Hoffmac wrote:
I have already done these things to it
1. Check the fuses and replaced a blown one
2. Regrounded it
3. I checked for anything blocking it and checked the seam.
This is my first RV and I have limited knowledge. I want to fix it myself due to finances.
I have not hooked the 30 amp back up to a power source yet. I am using a battery to run the slide out.
May-05-2017 08:45 AM
May-05-2017 08:23 AM
May-05-2017 06:42 AM
hoffmac wrote:
I hooked the battery up directly to the slide out motor and it went out then but it would not go back in.
May-05-2017 06:29 AM
DutchmenSport wrote:
It is possible your battery does not have enough "umph" to move the slides. (Low charger or could be going bad). Nothing wrong with plugging into shore power. Try it, see what happens.
May-05-2017 05:45 AM
May-05-2017 05:35 AM
May-05-2017 04:22 AM
