Slides- how far to retract?
DiskDoctr
On our NTU 2005 Cougar 304BHS, when we retract the slides, they come in level with the floor, then tip up just a bit at the limit.
This lifts the floor of the slide a little.
Question: Should I stop when the top stops, or continue until the slide limit stops it?
It seems as though I should stop when the slide stops and just before it starts to lift the floor, but what about the seal? Will this seal the slide properly?
Thanks!
18 REPLIES 18
time2roll
I recommend all-in or all-out. And should be able to be fully utilized in either position. Otherwise need to refer to the manual or manufacturer.
Lwiddis
Gee, Ken, I don't avoid my sofa when the slide is in. Winnebago has never said to do so. HEY, I need to sit down! You spring chickens.....
DiskDoctr
ken56 wrote:
Let it stop on its own. That means all the way in and that insures that the outer seal is contacting the slide frame. You do want to avoid walking on the slide floor when it is retracted though.
So we shouldn't use the couch with the slide in? It is a floor level slide, not elevated.
ken56
