Stable loads?
6pac
Is there such a thing as a top stable load for a Chevy 2500?
Chevy 2006 2500HD 4 x 4 Duramax / Allison srw cc sb Fh air bags
Lance 2005 model 881 Max
Doriece & Ernest ( 6pac )
2 REPLIES 2
wcjeep
I have the drill Stable Loads on my 2500 Dodge. Looks very similar to the Chevy No Drill 7310. I lowered my air bag pressure from 80psi to 40psi. The truck rides really nice when loaded. When empty I swing the Stable Loads out of the way.
Chevy No Drill
kerry4951
Torklift does not make an upper stable load for alot of the later Chevy/GMCs. Its due to the way the upper spring support mounts to the truck.Some have made home made ones. On my 09 dually I use the lower ones only...upper ones were never available from Torklift.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
