โAug-29-2018 08:48 PM
โDec-15-2018 11:21 AM
โNov-01-2018 01:52 PM
โOct-31-2018 07:01 PM
โOct-31-2018 06:57 PM
โOct-31-2018 06:38 PM
โOct-30-2018 06:54 PM
Buckeyeclan wrote:
I replace my entire floor this past spring on a 05 palomino hybrid. Found and repairs lots of leaks found before pad during the process. On mine all of the foam and both the top and under side layers of wood were removed. basically all that was left was the aluminum tube and bottom fabric. I made a grid out of 2x material to get some structure then a layer of 1/4 exterior grade ply under all full height walls and cabinets. Then anther layer of 1/4 ply to carry the traffic. Staggered all the joints. I did not use treated material as there is a chance that it could react to the aluminum. I also used the pink solid foam in the gaps of my grid for insulation. This stuff will not wick moisture like the original stuff. I think I have some pictures and will try to post them when I get a chance
โOct-29-2018 05:51 AM
โOct-28-2018 06:58 PM
โOct-28-2018 08:12 AM
โOct-28-2018 08:03 AM
fozrun wrote:
Thanks for the feedback.
I've got a new plan after finding some 1" aluminum channel at Lowe's. I'm going to start a frame at the front and attach new luan (and a waterproof membrane) under the aluminum square channels. Because they are light and not too expensive I'll use them at 12" centers and put them on top of the trailer frame that runs the length of the trailer on both sides. I'll jack up and support the sides at the front if needed to get back to square. I'll then rivet the channel to the outside frame using L brackets. I'll epoxy glue 1" hardwood blocks where the existing bolts go through the 2x4 blocks to the frame under the trailer. I'll then fill in with 1" sheets of insulation. On top of that frame I'll put 1/2 " ply (treated?), install the bolts to the frame and then put another layer of luan on which new vinyl plank flooring will go on. Sounds simple but I'm sure it will be some work and a few problems along the way.
At Lowes I put the channel on the floor and put the 1/2" ply on top, then a sheet of luan and the panels were very rigid with no movement. I'll be adding some weight with the 1/2" ply, but it shouldn't be too much.
โOct-28-2018 06:04 AM
โOct-26-2018 09:52 PM
โOct-26-2018 11:42 AM
โOct-26-2018 06:58 AM
