โMar-06-2014 05:55 AM
โMar-06-2014 05:57 PM
โMar-06-2014 05:51 PM
โMar-06-2014 04:14 PM
jmcgsd wrote:
I seriously doubt I'll ever need the AC in Sequoia.
The campground is at 6700'. The AC requirement is for DW when we camp at Bluegrass shows down in the flats.
As far as generator hours, at National parks they are normally pretty lenient, so I don't think that will be an issue.
As far as my battery, it's BIG! A 4D weighs about 140 pounds and is over 200 amp hours. There is also an independent SEC smart charger that is attached to it that will charge it pretty quickly.
If it weren't for the DW I wouldn't even be considering a 3kw.
โMar-06-2014 03:50 PM
โMar-06-2014 11:48 AM
โMar-06-2014 11:40 AM
donn0128 wrote:
Nothing. You have we weigh the necessity of having the AC running versus the weight penalty. You might consider starting out with a 2KW Honda. If that is not enough buy online a 2KW companion and the correct parallel kit and within a week you will have plenty of power.
โMar-06-2014 11:38 AM
IDman wrote:
We have two Yamaha 2000s but only take one with us most of the time as wife needs it to run hair dryer. IF we think it will be hot, thus needing A/C, we take both units. Saves on my back by usually having just the one 2000 to lift in/out of the pickup.
โMar-06-2014 10:31 AM
โMar-06-2014 08:22 AM
โMar-06-2014 07:50 AM
โMar-06-2014 07:43 AM
โMar-06-2014 07:03 AM
โMar-06-2014 06:55 AM
โMar-06-2014 06:52 AM
