Surge brakes
dennych1
Quick question when you have surge brakes can you backup with them without them activating. This question is for my neighbor I never had surge brakes
Thanks Dennis
3 REPLIES 3
All_I_could_aff
In less you put a significant force on the ball you should have nothing to worry about if for some reason you needed to back the trailer over a curb that would likely activate the brakes for a moment, in less the manual lockout or reverse light sensing lockout was activated
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
rekoj71
They are also usually spring loaded enough that when backing up slowly the spring will keep the trailer brakes from actuating.
If you watch it you will see that the hitch doesn't retract much into the brake actuator when backing.
Bionic_Man
Yes. They should either have a solenoid in the trailer that is activated by the reverse lights, or a lock out switch on the tongue of the trailer.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
