Swap from St tires to LT
ChuckNTruck
I dont want to start another LT vs ST debate. I just wanted to show how i did the swap on my trailer.
I used lift block designed and machined for trailer axles with larger u-bolts to lift the axles 2 inches. Then i swapped the 14in wheels with 205/75R14 tires to 15in wheels with LT235/75R15 tires. These are the smallest LT tires i could find. I have put about 1000-1500 miles on it so far and i have not noticed any difference in how it pulls or rides. But i like the extra 800lb capacity thee tires provide and the higher speed rating. I also added a BAL tire carrier so i wouldn't damage the rear bumper.
My X-chocks still fit between the tires perfectly and i have zero clearance issues anywhere.
2015 Ram 2500 CTD 4X4
2017 Heartland Sundance XLT 281DB
26 REPLIES 26
Hannibal
Looks good! Should be a bit less squishy in side winds.
I have to agree with JIMNLIN about the lift blocks. Might want to double check those.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
deltabravo
Video of the "SOA" conversion kit:
https://www.youtube.com/watch?v=LTrvsexgRK0
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
deltabravo
Huntindog wrote:
Huntindog wrote:
I got steel blocks here:Custom lift blocks
I have purchased from him several times. Talking to him, he seems to be an older gentleman that makes these things himself. Very good to deal with.
Looks like his blocks are much more affordable.
In my research, I found that for folks with "spring under axle", Dexter makes a conversion kit to do the "spring over axle" conversion.
Huntindog
JIMNLIN wrote:
However be warned suspension lift blocks on a trailer aren't the best idea for several reasons.
Side loading as a trailers tire/wheel and suspension slips sideway as the trailer goes around a corner or backing makes going to the next diameter U bolts.....heavier top plate.....and especially heavier spring keepers is a wise choice. Blocks add more leverage to all those components.
Some trucks come from the factory with lift blocks. In fact Ford was removing them for some customers for free at one time, when they wanted a lower ride height.
I have been using blocks on TTs for over 10 years, and LOTs of off road travel. No problems to date..
I do think that one should keep the size reasonable... But 2" is within my comfort zone.
Huntindog
100% boondocking
2 bathrooms, no waiting
17.5LRH commercial tires
Huntindog
deltabravo wrote:
Yikes. That's a 1997 vintage website. ick.
I could care less about a flashy up to date website.
Huntindog
100% boondocking
deltabravo
JIMNLIN
Moving to a LT is a great move for 40k-60k miles and 7-10 years of trouble free service on any trailer.
You may also want to check with your state dot folks if its legal to do so on a trailer. Haulers from certain states have reported suspension blocks they added on their trailers in commercial service not passing the required annual vehicle safety inspections.
I would do a monthly suspension check...especially U bolts and spring keepers.
Huntindog
time2roll wrote:
Blocks
Those blocks won't work for trailer springs.
They are 2.5" wide, trailer springs are usually 1.75" wide.
Huntindog
100% boondocking
Huntindog
ChuckNTruck wrote:
I used 2in blocks because these tires are 3 inches overall bigger than the stockers and i already had a few marks where the factory tires rubbed above them.
Also i got the blocks and U-bolt from
http://www.trailerblocks.com/
A little pricey but great quality!
Wow they sure are pricey.
When I did it, they only offered steel blocks with a maximum 1" thickness. So I ordered double and welded them together.
I see they now are offering aluminum blocks in many thicknesses...
And the prices are a lot more reasonable.
Huntindog
100% boondocking
Passin_Thru
I have an Arctic Fox 31W. I used Isuzu truck rims and put Michelin LT 15s on. Ride is smoother and height the same.
ChuckNTruck
amxpress wrote:
Hope you had the new tires balanced!
Yep, Lug centric balanced.
amxpress
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
ChuckNTruck
dodge guy wrote:
What is the LR of those LT's? I was looking for a set of LR "E"'s for my trailer but couldn't find a set in A LT.
My firestone load range Cs are single 1984lbs or double 1819lbs
The goodyear load range Ds are single 2094lbs or double 1929lbs
ChuckNTruck
Thanks. Those blocks are a little pricy considering they're just a chunk of bar stock. I guess you had to also raise the hitch head 2" to keep things level?
I just had to adjust my hitch from about a 7in drop to about a 3in drop. The equalizer shank i have had all the adjustment i needed.
Between the 2in block and bigger tires it lifted my trailer about 3-4 inches
Camper is nice and level now
