Nov-20-2013 06:45 AM
Nov-21-2013 07:37 AM
Nov-21-2013 06:38 AM
Nov-20-2013 06:32 PM
Bedlam wrote:popeyemth wrote:
If you don't have 2 minutes to fill the tank with water instead of dumping it half full,where do you get the 2 minutes to use it?
Never mind, that's why it's only half full 🙂
I'm not sure how you're filling your black tank, but I cannot get 15 gallons (half tank) in mine in 2 minutes at a dump station. What type of pump or water delivery system are you running in your TC, because I don't want be near the back splash when you flush.
Nov-20-2013 06:26 PM
Nov-20-2013 06:23 PM
Bedlam wrote:
Sometimes it how something is said and not the content. You can say quite rude or outlandish things if you phrase them properly yet can be edited if the candor is hard to swallow.
Nov-20-2013 06:13 PM
Nov-20-2013 06:06 PM
Bedlam wrote:JumboJet wrote:
Moderator deleted my post and didn't even give me the courtesy of a nasty gram.
Don't feel you're being the only one edited. Mods have enough work trying to keep the forums clean much less messaging people that should know better.
Nov-20-2013 05:59 PM
Nov-20-2013 05:56 PM
Nov-20-2013 05:37 PM
Nov-20-2013 05:34 PM
Nov-20-2013 05:21 PM
iwon415 wrote:
I'm always amazed at the number of people who don't use their bathrooms as they were intended. Don't see the use of having them otherwise.
Nov-20-2013 04:33 PM
Bedlam wrote:
I also have someone camping with me that uses much more paper than I do. I prefer to stay with something that breaks down, so I don't have to deal with build up or repeated flushes. The extra cost of the RV paper is peace of mind and is not that that expensive if you stock up when on sale locally.
Typically I get the tank to half or greater level with water before opening the blade valve and have not had trouble in any of my RV's.
Working more than full time and still getting away precludes me from testing paper samples from various vendors to see if they are compatible with my tank. There's places and people to see instead of watching paper dissolve or cleaning out holding tanks and sewer hoses.
Nov-20-2013 03:34 PM
Nov-20-2013 12:12 PM
