Travel Trailer Construction - Exterior Identification
DallasSteve
A recent thread addressed the construction of travel trailers and it identified 2 basic styles of construction:
Old - wood stud, fiberglass insulation, aluminum siding
New - aluminum tubing, solid foam insulation, fiberglass skin
When I am browsing travel trailers for sale I see basically two styles of appearance as represented in this photo. Is the bottom-left trailer appearance (with the ridges on the wall) always the Old construction and the top-right (with the flat walls) always the New construction?
2022 JAYCO JAY FLIGHT SLX 8 324BDS
2022 FORD F-250 XL CREW CAB 4X4
All my exes live in Texas, that's why I live in an RV
17 REPLIES 17
azdryheat
I don't believe any builder is using wood any more. It's good that you're looking into how they're built. Many trailers are built so cheaply it's a wonder they hold together.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
rexlion
"Always" is a strong word, so let's say almost always. I can think of one TT made in Canada that looks like your #2 example, but instead of a foam laminate sandwich with aluminum studs the Prolite has thicker molded-fiberglass panels that are bonded together at overlapping points with a sort of adhesive... no framing, As I understand it.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
azrving
They still build new ones with aluminum like the lower pic.
