Sep-08-2014 08:19 PM
Sep-11-2014 05:21 PM
sky_free wrote:ironhorsejs wrote:
So tires and rims for sure. And we have Springworks up where I live that's all they do is custom spring work.. Question on the springs though. The unit im looking at is 2874 Dry weight with gen and water/gear most likely 3200-4000max but definatly now any where near 4500 pounds if the springs are rated for 6K weight I still have some room to grow right? maybe add airbags to help ride? the springs only really have the weight of the bed as it sits on the driveway. is there really any need for springwork to be done?
Arctic Fox's run about 1,000 over the listed dry weight once you add options. There has been lots of discussion about that and the "Fox Value Package" which is mandatory and adds 500 lbs. The A/C and other common options add another 500lbs. Add 51 gallons of fresh water and you are at 4,374 lbs. Most people carry stuff in their TC's like food and clothes, so add another 300 lbs for that, for a grand total of 4,674 lbs. This number matches up well with actual scale weight reports from this site. I'm not trying to discourage you, but you should know what you are getting into.
Sep-11-2014 11:12 AM
Sep-11-2014 10:52 AM
lawrosa wrote:I can go to DMV and register my truck, LEGALLY, for a weight higher than what the door sticker says. As long as I'm within my registered weight, then I won't get an overweight ticket.
No state I know will allow you to register a pick up higher then the GVWR on the door tag. You can register at a lower to save money on states that charge by GVW of vehicle.
If you can modify and prove an increase in GVWR and get your door tag changed, and registration I would like to see that...
*The weight class of the vehicle is determined by information contained in the manufacturer's statement of origin / Title(If not defined here, the following resources will be used):
The application for renewal of registration
The Branham Reference Book
MVC's weight class manual
If the manufacturer's shipping weight is disputable or unavailable, the applicant may be required to have the car weighed on a certified scale under Title 39:3-8. This weight will be considered the manufacturer's shipping weight.
Non-commercial trucks
The fee is based on the vehicle's gross weight.
Customer should be advised to have weight on the title corrected by contacting:
Motor Vehicle Commission
P.O. Box 141
225 East State Street
Trenton, New Jersey 08666-0141
Sep-11-2014 08:31 AM
Sep-11-2014 08:18 AM
lawrosa wrote:
No state I know will allow you to register a pick up higher then the GVWR on the door tag."
Sep-10-2014 06:19 PM
I'm not going to go 'round and 'round on this any more, I can say with 100% certainty that I could go in to VA DMV and register my pickup for a higher GVWR than what's on my door. They couldn't care less, they get more money out of me that way. The GVWR on my title will remain the same but my registration will be whatever I tell them I want to pay for.
Sep-10-2014 05:48 PM
lawrosa wrote:
http://www.drivetrainshop.com/Ford_10_25_10_5_s/97.htm
But no weight rating is specified....
Sep-10-2014 05:11 PM
Sep-10-2014 04:53 PM
Sep-10-2014 04:39 PM
Sep-10-2014 04:27 PM
ironhorsejs wrote:lawrosa wrote:V-469k
V for vandyke plant
K for the revision
469 is the model #.. I find no info..
Can you link something?
I just strait googled it.
Sep-10-2014 03:50 PM
V for vandyke plant
K for the revision
Sep-10-2014 03:38 PM
V-469k
Sep-10-2014 03:36 PM
Since you already have the upper overload springs that are part of the camper package, plan on using devices that will engage them sooner so the truck does not have to sag 3" before engagement. If you still need more support, add devices to the lower overload spring to do the same. These device can be built by you or purchased from companies like Torklift. I doubt you will need airbags unless you tow heavy or your camper is heavier on one side requiring some form of equalization to level left to right.
