TT tires!
Tikkamike
What Ply tires do you guys use on your trailers? Mine is a 22' so not super heavy, but I will be off road a little. right now it has 2 4 ply and 2 6 ply neither of which are adequate in my opinion. Just wondering what you guys use.
2 REPLIES 2
coolbreeze01
I've had good luck with E rated ST tires.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
n7bsn
Someone certainly went "cheap". Check the pressure rating for the rims (assuming they all match) and get tires that match that rating.
Also what are the tires, I'm guessing "P", when they should be LT or ST.
SWAG the tires should be D rated
Lots about tire rating here
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
