Jul-28-2016 08:26 PM
Aug-01-2016 12:23 PM
RoyBell wrote:So what? What is the point of ignoring the numbers with such a blanket statement? The OP asked for help - I'm giving it to her.
It's a half ton truck and has been stated many times. Any half ton truck should have a payload of 1400-1800 lbs without even looking at the sticker.
Aug-01-2016 12:17 PM
Aug-01-2016 12:09 PM
abimarye wrote:2012Coleman wrote:abimarye wrote:I asked about the info on the door jamb sticker - any reason you can't give that? Is 9100 the tow capacity?2012Coleman wrote:
So, what are the specs on your truck? Don't stick your head in the sand on this.
I haven't by any means!
Max trailer weight can be 9100#
GCWR 15,000#
GVWR 7,200#
Brake assist and transmission cooler came with the tow package on the truck so are covered by the bumper to bumper warranty
Also have checked the axle weight and hitch weight and I'm well under if I proceed with the Grand Designs 2150 with the Equalizer hitch. Just don't have those numbers memorized. Both Chevy and the RV dealer gave their approval and ran all the calculations at my request.
Getting closer and closer!!
Make and model of the truck? Engine displacement? Look at the receiver and see what it is rated for. Above all, the dealer wants to make a sale.
Only in bizzaro world would they tell you that your truck could not tow the TT you are interested in.
Nice TT though - hope it works out.
9100 is the tow capacity. It's a Chevy Silverado 1500 crew cab standard bed with the tow package, 5,3 engine and 3.48 axle
Aug-01-2016 11:25 AM
GCWR 15,000#
GVWR 7,200#
Aug-01-2016 10:51 AM
GCWR 15,000#
GVWR 7,200#
Aug-01-2016 09:20 AM
Aug-01-2016 08:31 AM
Aug-01-2016 08:30 AM
Aug-01-2016 08:20 AM
Jul-31-2016 08:38 PM
pianotuna wrote:
Once you have had the "rental" trip under your belt and have purchased an RV, I strongly recommend you add a modest solar system. A 400 watt system may nearly eliminate generator run time, other than for operating the roof air conditioner.
Jul-31-2016 06:14 PM
Jul-31-2016 11:41 AM
patperry2766 wrote:
Lance 2212
Have you considered a small toyhauler?
Jul-31-2016 10:39 AM
Jul-31-2016 09:11 AM
abimarye wrote:
What did you do for basic deployments like normal wind/hail? Just find a KOA or good sam?
