Ventline replacement vent clip
tourusa
Good evening
I’ve been replacing the vent line wedge shaped covers and encountered an issue,with the clip and the refitting procedure to secure the hinge side , I’ve used a pair of needle nose pliers to squeeze it back into place any input advise appreciated as the clip wiggles, do I need to squeeze it more so.
Clip is called ventline spring clip
Thanks
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
3 REPLIES 3
tourusa
Hi, thanks for your reply I did find this link on the how to put the clip back on may have another go with some needle nose pliers see if I can get it tight fix
https://www.etrailer.com/question-88437.html
F350 dually 2020
ITEM # BWRVK3305
2112
I couldn't get mine back on when I replaced my 3 vent covers about 4 years ago so I left them off. Do I really need them in place? The vents raise and lower, don't leak, what do the clips do?
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
tourusa
https://www.walmart.com/ip/Ventline-Spring-Clip-Ventadome-Trailer-Roof-Vent-w-Wedge-Shaped-Plastic-Dome/929691227
F350 dually 2020
ITEM # BWRVK3305
