Vinyl Insert Molding
Cheyenps
I need to buy new vinyl insert molding to go around the baggage doors on my TT. As you can see it has discolored and shrunk.
There seems to be two types of this stuff. The common type used at the corners is stiff and shiny. What I need for these doors is much softer and more pliable so it will go around corners. So far I have not been able to find it anywhere and have ordered the wrong stuff online more than once.
It would help if I knew what the different types were called. I used to be able to find it everywhere but it seems to have disappeared.
Any suggestions?
Steve
2008 Thor California Summit 26RLS
2003 Ford F-350 SRW Crew Cab Utility
4 REPLIES 4
Dog_Folks
Cheyenps wrote:
Dog Folks wrote:
Try letting your trim sit in boiling waster for a little bit. (trail and error for how long) That will usually soften it enough to install.
Yes. As soon as it cools down it pops out of the corners.
Don't know about that. It always worked for me. Obviously, it only works sometimes.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
Cheyenps
Steve
Dog_Folks
Our Rig:
buzzard616
Have you tried heating the stuff you have.
Stu
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
