Water Heater Intake Line dripping
Rthomas61
Question...
Noticed a slight "drip" coming from the intake line of my water heater, inside the RV. It's Pex tubing to a "screw type" fitting and then to the water heater. Tightened the fitting before winterizing and THOUGHT I took care of it; the leak seemed to stop.
Just checked out the trailer from a long winters nap and found some antifreeze in a little cup I put under that fitting so apparently, my fix didn't work too well.
Before I go draining the antifreeze and unscrewing the fitting, is there anything I need to know? Is there some sort of "gasket" under that fitting that may need to be replaced or do they use Teflon tape to seal it? I just don't want any major headaches since I've never taken one apart before.
It's only dripping from the "in" line (cold)
Thanks in advance!
Bob
2015 Chevy Silverado 2500HD Crew Cab 6.0 V8
2013 KZ Sportsmen 280BH Show Stopper
4 REPLIES 4
Mandalay_Parr
You can always call a plumber if you need help.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Rthomas61
Ok. Thanks for the replies. Sounds like a somewhat easy fix then. Supposed to tickle 70 degrees this week. Might be time to give it a look. Only 27 more days until she gets dragged to the seasonal site! FINALLY!!
Thanks again!
Bob
Old-Biscuit
westend wrote:
Most of those fittings have a rubber washer inside to seal to a pipe surface. I would disconnect it, tape and dope the connection, retighten.
X2
Check washer for tears/gouges/nits.
Replace if any signs of damage.
Replacement packs of washers available at Home Depot/Lowes/Aces etc.
Could be flat, tapered, coned based on type of fittings the nut screws onto
westend
'03 F-250 4x4 CC
