Water Heater Probs
mtkbuckeye
Camping now. When I left the house water heater worked . Get to campground no Worky. Its a suburban. Will not work on either gas or electric. When turn over to gas does not even attempt to light-no clicky sounds. The light on the switch no allumination like it should when we first turn the switch on.
Any ideas on what to check for?? My trailer is 8 years old so I wonder if its shot?????
2005 Salem
2004 Ford Excursion Limited 6.0L 4x4 Diesel
"If we ever forget that we're one nation under God then we will be a nation gone under." - Ronald Reagan
7 REPLIES 7
mtkbuckeye
Thanks for all the help. I was able to get it to light and work great. I might not have had the heater full of water when I was trying at the campground and made certain of it being full before I tried to start it again.
By the way if anyone is interested.....Bear Lake State Park on the Utah side of Bear Lake is a great place to camp!! We had a great trip!
2005 Salem
AtomicChicken
What model water heater?
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
krobbe
Open the outside cover and look for a reset button. The button on mine is not obvious but it's behind a rubber grommet. It trips when it gets too hot on gas or electric.
I need to replace the thermostat on it to correct the problem. Hope this is your issue.
Me'62, DW'67, DS'04, DD'07
'03 Chevy Suburban 2500LT 4WD Vortec8.1L 4L85-E 3.73 CurtClassV
'09 BulletPremier295BHS 33'4" 7200#Loaded 1100#Tongue Equal-i-zerHitch Tires:Kumho857
Pics
mtkbuckeye
At campground plugged into power. At home did both gas AND electric to make sure both worked as I knew we would have hook up. I checked the breaker at my converter and all seems good. Where else is there a fuse ? I'm sure it's a lack of power issue I think as I'm not getting that switch to light inside my trailer where I turn it on to start it and then it clicks on when using gas. Not sure where else there might be a fuse. I checked all my wiring up to it and seems normal. But, I'm no electrician.
Thanks for the help if you guys can think of anything else.......
2005 Salem
David01
Make sure you have water in the hot water tank!
AtomicChicken
You're plugged into power at the campground? What mode were you using at home on the water heater (gas/electric/both)? Check those fuses as mentioned.
2007 F-150
fun_w_son
check the fuses. weather on gas or electric.. it still needs power to work. also check the Battery, may need 12v instead of 110??
2007 GMC Duramax
2007 VR1 310BHS
