Water pressure regulator -- Fail?
mleekamp
We just got back from a great trip to Cheyenne Mtn State Park. But here's the thing....
At all our stops we had water hook up. I used a water regulator with a gauge...hoping to get a read on the pressure. It read from 70 to 80 psi depending on the campground we were at. Laugh if you wish, but "just in case" I added my non-gauged regulator before the gauged regulator...both supposed to regulate to 45-50 psi. Again, gauge reads 7-80 psi. So, I ended up filling the tank and using the pump.
Question is, why would something set to regulate to 45-50 psi still show high pressure? Even with water running, it was too high. I worried about it to the point I did not just hook it up but filled the tank.
18 REPLIES 18
D_E_Bishop
I can't really in this era of litigious consumers that any company would label and sell a flow restrictor as a pressure regulator. I think that if that were true, we would be reading case after case of water line failures in these forums. Marshall Brass makes a variety of regulators that are well under the $70 price, are all of these just flow reducers?
I would guess that Valterra's regulators are made by Marshal or some other reputable company and Valterra is a really big RV accessories supplier, can't believe they are going to falsely label a product.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
mleekamp
Bruce, Thanks, this is what I thought but wanted it to come from others with experience. I looked at the true regulators just last night after getting home. I wondered if the cheap ones were just flow restrictors vs. true regulator.
nomad297
The cheap "regulators" are really nothing more than flow restrictors. They will reduce the flow pressure, but most of them will not reduce the static pressure -- the pressure will eventually build up on the low pressure side. You need to pay about $70.00 if you want to get a real pressure regulator.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
westend
Failed gauge but functioning regulator?
'03 F-250 4x4 CC
