Water Tank Leak (my fault)
Marsland
Well this is embarrassing 😮 :M ! But I need some advice on water tank repair.
This is my story. In my exuberance to make my TT more cold weather protected I dropped the underbelly (coroplast) and after checking out the tanks, connections, duct work, and everything else I proceeded to put in a layer of Reflectix. Not much more insulation but more than it had to start with.
Now the fresh water tank rests on the passenger side frame rail and extends to close to the other side. Well on the passenger side the manufacturer used short screws to attach the coroplast to the frame below the tank. I knew that :R cause I took it apart!!! But in my haste to put everything back together I forgot and used a long screw. (expletive deleted)(expletive deleted)(expletive deleted)!!!!!!
My question is (finally) can this hole in my tank be repaired with a reasonable chance of success or should I swallow hard and purchase a new tank? If it were exposed I would more than likely try to repair but being covered I don't want to unbutton everything more often than I have to.
Thanks,
Richard
1 (Re)tired DH
1 Terrific DW
2012 Keystone Bullet 284RLS
2012 Ford F150 S/Crew ECOBoost
ScanGaugeII
17 REPLIES 17
Fire19
I have repaired many plastic tanks with a soldering iron and a gallon milk jug. Just cut the milk jug up in to a 2"square and with a wide soldering iron just keep going over the pathches and keep adding them on there till you build up the area.
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
NanciL
I would use West Systems "G" flex epoxy.
Any West Marine store carries it.
Don't use any old epoxy. Many of them are not compatable with poly material
Call West Systems up and they will advise you.
Jack L
Jack & Nanci
WoodGlue
I've seen tank repairs being done with a small piece of a gallon water jug (the flexible kind of frosted jug) with a liberal amount of superglue - and well, you get the idea. I'd go over the area with several layers of patches, each one getting a bit larger than the last.
If it works, great news! If not, then maybe a new tank?
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
