What to use to keep battery charged while sitting?
DatacomGuy
We keep our TT in a storage yard while not using. Whilst i pull the fuse (my version of a disconnect) from the power lead, it still loses a bit of charge while sitting.
My wonderful (sarcasm) helium fridge requires a fully charged battery to run, even if on propane. Itll fire up, but not cool.. So, precooling the fridge a day or two prior to a trip doesnt work and our first 24 hours camping is with a warm fridge and multiple coolers full of ice. And a grumpy owner.
Id like to install something to fix this issue.. Whether its a minder or a solar setup..
What would you do or recommend? Or am i missing something?
2015 Shadow Cruiser 280QBS | 2015 Ford Expedition XLT HD Tow
Equal-i-zer E4 12K# WDH
39 REPLIES 39
We_Cant_Wait
I'd take it home 1) to keep it charged 2) because every time I turn around there's another thread about someone's battery being stolen from the trl while in a storage yard. Every TT I had it took about 2 minutes to remove the battery, in fact I left a small wrench right in the battery box for removing the cables.
Community Alumni
Not applicable
To the OP, slightly off topic but my Atwood helium fridge works great on propane, are you sure there's not another specific issue with yours?
dodge_guy
I use a small 2 watt solar charger mounted on the top of my propane tank cover. it puts out 500Ma which is enough for a trickle charge. For what you propose I would definitely go at least with an 80 watt panel and a good charge controller.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
westend
I'd suggest a simple solar system. Solar will do the best job of maintaining your batteries.
'03 F-250 4x4 CC
old_guy
take the battery home with you and put it on a battery tender.
hddecker
The only thing your missing is solar, it's the best way to maintain batteries without shore power. If you do any boondocking your going to want to keep your batteries topped up.
toedtoes
You say it's stored in a "storage yard". Is the TT covered when in storage? If so, then solar isn't going to help you keep the battery charged while in storage. In that case, I would look into the trickle charger.
Will the storage yard let you plug into to shore power for a couple days before you take it out of storage? If so, you could stop by on day 1 and plug it in to shore power, then stop by on day 2 and start the fridge, then on day 3 go RVing. That will charge the battery and get the fridge cold before your trip. And if all you're doing is charging the battery and turning on the fridge, you're not using a lot of the storage yard's electricity.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
pianotuna
Nomad III
Nomad III
Hi,
Definitely consider solar.
Regards, Don
time2roll
robsouth
Do you have access to shore power while in storage? If not, then solar is your best bet.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
