Winegard Rayzar TV Antenna
wincrasher65
I got this cool, compact thin TV antenna to use on my T@G. Some folks have reported mounting this on the underside of their AC shroud.
http://wincrasher.blogspot.com/2015/04/winegard-rayzar-tv-antenna.html
2016 Winnebago Travato 59K, 2017 Allegro 32SA
Follow my blog: www.wincrasher.blogspot.com
Our Facebook group is: Class B Camper Vans
1 REPLY 1
SCVJeff
This is not an omni directional antenna, it's more of a figure 8 bi-directional pattern. Additionally you install it vertically, not horizontally. So strictly speaking, NO it will not work laying flat on a shroud, nor will it perform in a fixed position such as a window because of the radiation pattern. I suspect that's explained in the instructions?
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
