Need RAM 5500 flat bed height
bigridetime
Does anyone know the height of the flatbed on a stock 2022+ RAM 5500?
Doing a new build and considering the Backstop kit, but want to stay under 13'6" if possible, so trying to figure out how high the stock RAM 5500 is.
8 REPLIES 8
deltabravo
It depends on what brand of flatbed you have. There is no end-all be-all height.
3_tons
Back home - PMโ€™ed youโ€ฆ
3 tons
3_tons
bigridetime wrote:
Thanks for the feedback. I am planning to lift and add some big tires, probably using the Buckstop kit...which will add 7" of height. With a Host Yukon or Mammoth and a low profile A/C unit, to stay under 13'6" I think the bed needs to be no more than 42" high stock.
Bedlam -thanks for the measurement. if 42" is right, it will just work!
3 tons - thanks for the info. let me know when you get back in town - would love to bounce some more questions by you.
Has anyone had the Buckstop kit installed?
https://www.buckstopinc.com/single-wheel-conversions.html
Will doโ€ฆ
noteven
Take a look at RAM truck oem website for โ€œbody builderโ€ or โ€œupfitterโ€ manuals. There will be complete dimensions, departure angles, recommend tire clearances, etc etc available.
bigridetime
Bedlam
Moderator
Moderator
Typical deck height is about 42", so about half a foot higher than a pickup bed.
3_tons
I have a 2023 Ram 5500 4x4, 60โ€ C/A with a 9โ€™-4โ€ skirted steel CM bed (90โ€ width) and Eagle Cap 995 with basementโ€ฆWhile I canโ€™t provide you the exact number at the moment (Iโ€™m currently overseas for another week or soโ€ฆ), itโ€™s just under 13โ€™-6โ€ to the top of the air conditioner, and the CM bed installed rest about 6โ€ taller than my previous rear edge of truck-bed, a 2016 3500 4x4 LB DRW - my garage door is 14โ€™ (13โ€™-10โ€ with moulding)..
Feel free to PM me if you likeโ€ฆ
3 tons
mike_kellie
Do you mean from the stock truck frame rails to the ground? I can't answer because I have a 2015 on factory 19.5 Alcola wheels with 4 wheel drive. Asking about the height from the flat bed frame rails to the ground from any manufacturer could get you various answers, all of the right to the respective rig. Maybe this helps?
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
