Baltimore Tunnel
LIGirlatheart
We are traveling from NY to Yorktown VA on 95 with our 5th wheel. Can we travel thru the Baltimore tunnel? If not what would be the alternate route to take? We will then continue to Emerald Island NC on Rt 17. Will we have any issues with height of our 5th wheel? Looking for the right route and the best way around any other issues. Can anyone out there assist me? Please.
17 REPLIES 17
Lwiddis
RVing on the back roads of America require you know your height, width, length and weight. Can get rather messy if you don’t.
LIGirlatheart
When would we pick up 695? Yes I will make sure to measure our height.
Merrykalia
You can always go 695 around Baltimore so you don't have to travel thru the tunnel. It might simplify things immensely. Unless you are over-height, you should have no problem at all with Rt 17. Semi-trucks use it all the time and you are probably not as tall as they are. Ours is 13'2". You need to KNOW EXACTLY how tall you are, so measure it, don't guess.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
