โJan-13-2015 07:09 AM
โJan-19-2015 11:27 AM
โJan-18-2015 08:34 PM
โJan-18-2015 10:21 AM
โJan-18-2015 09:53 AM
Have you emailed him and asked him?
โJan-18-2015 08:26 AM
briansue wrote:rule 2 is ' you can not be more knowledgeable than me because i am an expert on everything.
I am not sure what this means as only one person on this forum has claimed to be an EXPERT on DPFs and LSD as opposed to ULSD. I have been asking the EXPERT for answer to questions for several years now and have had no answers to my questions. I have repeatedly stated that I know nothing and am no expert - I only ask questions. So I Google for answers since the EXPERT does not answer questions in a way anyone can understand. When I do Google all I can find are answers that conflict with what the EXPERT is telling us.
So I continue to ask the EXPERT for answers. Since I know nothing I do get confused about this whole topic which is why I keep asking questions. I have probably oversimplified some things and used incorrect terminology. I am sorry that I do not understand. Based on what I have found on the internet on websites I have referenced in this thread I think I have learned a few things. But then there is conflicting information. I incorrectly say that sulfur clogs DPFs - which is one of my oversimplifications. I did not want to go into the whole explanation of particulates and PPMs and burning fuel creating soot and ash from the particulates. At least that is my understanding of what happens based on what many internet websites say. Is there another way to explain or is this correct? I do not know. That is why I ask questions.
Based on any number of posts above in this thread it does seem to me that soot and ash from burned particulates found in diesel fuel are what the DPF is there to filter. This soot and ash can then be burned off by a process called regeneration. But the DPF is designed for fuel containing no more than 15ppm of sulfur - and sulfur is at least one of the particulates causing the soot and ash the DPF filters. So let's say the fuel in Mexico has as little as 300ppm of sulfur - which is 20 times the sulfur recommended/required to be used with these engines. Would it not be safe to assume (I hate to assume) that having 20 times as much sulfur in the fuel would cause a substantial increase in the amount of soot and ash finding its way to the DPF? I am asking. I do not know. But what I find on the internet indicates this is what happens and why notices on every diesel fuel pump in the US says 15ppm fuel MUST be used in vehicle from the year 2007 on.
According to still more found on the internet I have found any number of websites which say that regeneration alone will not completely clean a DPF and eventually the DPF will have to be removed for cleaning or the DPF will have to be replaced. Once again this leads me to believe that more soot and ash will require that the DPF be cleaned or replaced sooner. But I do not know so I ask questions that do not get answered here.
Then there is the question of a DPF that is becoming restricted (maybe not yet clogged but not passing as much exhaust as it should) and causing back pressure to parts of the engine. This should cause regeneration. But what I do not find an answer to is if regeneration does not completely clean the DPF will there be a slowly increasing amount of back pressure on vital engine components as has been stated on websites I have found. I do not know. I cannot get answers.
Another point that has been raised by others has to do with heat generated by the DPF or in the DPF during regeneration and if this heat, or should we say an increase in the number of times the system experiences the high temperatures, could cause other damage to the DPF or other components of the vehicle.
Mr. White says . . .Unfortunately, because there is no information about the make, model year, and circumstances surrounding the above, it is impossible to comment, other than to say that the claims in the quote have NOTHING TO DO WITH MEXICAN DIESEL FUEL. THE AMOUNT OF SULFUR IN DIESEL FUEL HAS NOTHING TO DO WITH THE MECHANICS OF SOOT COLLECTION IN A DPF. As I have already mentioned in earlier posts, clogged DPFs happened very rarely in the earliest model years of DPF technology, and are not something the average owner should be concerned about. Millions of diesel pickups are on the road with DPFs and clogging is virtually unheard of these days.
CLOGGED DPFs, AS MENTIONED ABOVE, ARE A COMPLETELY SEPARATE TOPIC TO THE AMOUNT OF SULFUR IN MEXICAN DIESEL FUEL. There is no connection between the two. The questioner has an unreasonable and unjustified fear of DPFs.
I have highlighted a few words by changing them to upper case. This is what mystifies me. Everything else I have ever read leads me to understand that it is the higher sulfur content that becomes soot and/or ash that is collected by the DPF and eventually starts to clog the DPF. What Mr. White says in phrases quoted here are in total conflict with everything else I have ever heard of or read about this whole topic. So now Mr. White seems to be saying that ppm of sulfur has nothing to do with the DPF. Does this mean that burning sulfur in the engine DOES NOT cause soot and ash that is collected by the DPF? Why then does the US require special fuel? Why can't we all just burn high sulfur fuel? What is it that does clog the DPF if it is not soot and ash from burned sulfur? Why do DPFs eventually have to be cleaned of this soot and ash? I can't find answers. The EXPERT is not telling us.
I am not trying to cause trouble. We still have a 2006 and will not upgrade until we know a lot more about all of this fuel stuff. Since we still cannot find satisfactory answers we stay in 2006. I sure wish someone out there could answer these questions in a way that a layman with no technical knowledge could understand.
โJan-18-2015 08:02 AM
โJan-17-2015 09:52 PM
โJan-17-2015 06:05 PM
โJan-17-2015 09:46 AM
โJan-17-2015 04:04 AM
Ed White wrote:
I'm leaving you folks now to stew in your own juices until next season.
All the Best
Ed
โJan-16-2015 09:37 PM
For example, a high sulfur content diesel produces more particles. Lower sulfur fuel produces fewer particles, and allows use of particulate filters.
โJan-16-2015 05:50 PM
briansue wrote:
So the confusion continues. A DPF filters sulfur. It is designed to filter sulfur from fuel containing 15ppm of sulfur. Fuel that is not designed for a DPF system can contain up to 500ppm of sulfur. Since the day they came our with this equipment and to this day there are continual warnings not to put 500ppm fuel in a system designed for 15ppm fuel. Since the DPF is supposed to filter sulfur from a 15ppm system it would stand to reason and common sense that fuel contain a great deal more than the device is designed for might have some adverse effect on that device. Seems pretty basic and simple to me. Even some fuel containing 15ppm has been known to clog some DPFs. So why would 500ppm be said to have no effect on a DPF? As far as the computer codes - the only codes ever previously mentioned that some tech or someone special trainee with a laptop has been said to be able to reset are those related to the DPF - my question had to do with all the other engine components that could be effected by a clogged DPF which are in the many websites I provided addresses for in my posts. In all my searches on this topic the only place I have ever heard anyone claim this is not so is on this forum - where the writer does not disclose sources since they are top secret. Let the buyer beware.
โJan-16-2015 04:57 PM
โJan-16-2015 04:31 PM
โJan-16-2015 04:08 PM
