โOct-28-2020 05:14 AM
โDec-23-2020 09:13 PM
โDec-23-2020 06:47 PM
โDec-22-2020 01:20 PM
โDec-22-2020 12:28 PM
โDec-22-2020 06:42 AM
kfp673 wrote:Once you connect them in series you have one twelve volt battery. Do not connect anything to the battery to battery jumper and all works fine.
Thanks again all. Quick question on charging 6V batteries. If I go with 2 and wire them in series, does the charger built into the trailer still charge both as it would a 12V battery when plugged into shore power? Also, when using a standard charger (not the built in camper charger) how do you properly charge them together? Do you put your charger clamps on the same terminal as the RV would, 1 batteries + and the other batteries - with the jumper from + to - still attached? Thanks!
โDec-21-2020 08:50 PM
valhalla360 wrote:pianotuna wrote:
Valhalla360,
A solar system is the nearest thing to a free lunch anyone is likely to see. My 2005 panels continue to produce their rated output.
So someone came by and installed a free solar system? Where do I sign up?
I've had solar systems before. They have their place but it's silly to drop a few thousand for a system that will only provide benefit 5-6 weekends per year when the OP has a perfectly functional generator.
A little trickle charging system would be much cheaper but won't negate the need for a generator on those 5-6 weekends per year.
โNov-28-2020 09:06 AM
โNov-23-2020 06:55 PM
โNov-21-2020 01:58 PM
โNov-18-2020 08:18 PM
โNov-18-2020 07:18 PM
โNov-18-2020 06:47 PM
โNov-18-2020 06:49 AM
pnichols wrote:pianotuna wrote:
Time to roll I did five years of part time without a generator. Once I was full time, I had to be a power pole princess, or upgrade the solar, or get a generator. I made a HUGE mistake and got a generator.
Don, how did/do you - worst case - thumb you nose at the weather and camping location in complete comfort with no generator? :h
โNov-18-2020 04:24 AM
