The sites are mostly level with decent space in between. If you are looking for shade then if you look at the campground map when pulling in the sites to the right numbered 1-139 are more woodsy and shady. Sites 202 thru 215 are more out in the open. The only sites I would try to avoid are the 181,183,185,187,191,193 because the site is level where you will park your rig but the a prety big drop off to where the firpit is.
As for the rest of the sites they are all fine, back up mostly to trees
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
