Will motor home freeze traveling in cold weather?
Thetollies
We would like to travel to Texas, but the weather in Mo is very cold, and we would like to know if we run the gas furnace on the motor home while traveling, will that keep the water lines, sewer lines & etc from freezing????
18 REPLIES 18
Hank_MI
We're heading to Fl from MI in February. The MH will stay winterized until we get to warmer temps. That may be on the way or not until FL, we'll have to wait and see. We carry gallon jugs of water to flush the toilet, wash hands, etc.
nelson
I would not put water in the lines, Use jugs of water for what you need and you ahould be fine.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
tandkj
All of your lines should have been winterized by now. Just leave the pink stuff in until you get to TX and then summerize. Re-winterize before going back north if necessary. Cost should be less than $20 and you are safe.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot Custom build
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
mpierce
Probably not. Unless ALL lines are enclosed in heated areas, the wind will freeze them.
