Mar-03-2017 10:12 PM
Mar-12-2017 02:11 PM
Mar-12-2017 01:30 PM
Mar-12-2017 12:21 PM
Tom_M wrote:
Mar-12-2017 07:05 AM
Almot wrote:I am one that favors the portable solution. I have three panels, two of which are portable. One of my portable panels is a 180 watt flexible which I framed with aluminum channel. My 125 watt glass panel which is on the roof weighs 27 pounds and my 180 watt flexible panel weighs 12 pounds. I mounted my portable panels on the side of my coach. If that side of my coach is toward the sun I can leave them attached, otherwise I remove them and place them on the ground. I've had my flexible panel for three years and it is still working well. Flexible panels are actually more efficient than similar glass panels.
2 reasons:
1) They are (usually) less efficient per sq ft, i.e. 100W flexible is larger than 100W rigid.
2) More difficult to make a frame to hold it in tilted position. To rigid you just bolt 2 hind legs of alum angle or PVC pipes.
I would also think that they are less durable, there is no glass, they use some clear film on top.
But they can be a good choice for roof mount on expensive MH where you don't want to drill any holes. I'm talking about flexible that you can roll out, not those that come with rudimentary metal trim around the perimeter and can "flex" but not roll out. You probably bought the latter type - with metal trim.
Mar-09-2017 05:02 PM
hedge wrote:.
Why would a flexible panel be a poor choice for portable?
Mar-09-2017 12:35 PM
Mar-09-2017 12:29 PM
Mar-07-2017 02:09 PM
Mar-04-2017 03:55 PM
Mar-04-2017 09:30 AM
Mar-04-2017 08:43 AM
champdog wrote:Good plan except for the flex panel choice. I would think that a smaller, rigid module would be a better choice, less chance of module failure and easier deployment. The only trade-off is weight and there is not enough to worry about with these sized modules.
THANKS! Ill look into those connectors, they look awsome. I thought Id pick up a semi flex panel because their lite. Ive seen pvc frames or legs, good idea for sure. We boondock quite a bit in the trees. Thought moveable panel would provide extra when the California forest is blocking some of the 200w on the roof. Ive seen some posts with a fuse between the panels and the cc and some without. I thought a shut off switch would be a good idea so just bought a manual reset circuit breaker. tying a pigtail into the pv wires before the cc seemed like its the same as if I bought another set of mc4 y connectors.Thanks again
Mar-03-2017 11:22 PM
Mar-03-2017 10:48 PM
