Adding Bunk Beds to my Class A
JimMartin
We have decided to add some bunk beds in the rear slide out of my 2003 Georgie Boy Pursuit 3205DS. The rear slide out a large cabinet area w/drawers and a closet in it which I will remove to build to bunk beds there. I will also move the queen size island bed all the way over to the opposite side wall to add some walking space between the beds.
Here's some before pictures:
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
2003 Georgie Boy Pursuit 35', V10 F53 Chassis
11 REPLIES 11
Corkey05
Great work! .... bet it feels good to step back and see something you wanted in front of you, and you did it all yourself. Looks like it will work out perfect for those added beds you needed.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
JimMartin
We bought the 5" memory foam twin mattresses from Walmart. I cut them to size with a large bread knife. We used a pillow sham to cover the window. It comes on and off.
HappyCampers227
WoW! Great job! Looks professional. Thanks for sharing.
Happy Campers 227
2013 Dodge Ram 2500 Diesel 4x4
2016 Jayco Eagle 323 LKTS
The Happy Campers Facebook Page
JimMartin
Just an update:
Got most on the Oak trim stained to match the wood in the RV. Looks better in pictures. Still waiting on the mattresses' I order to come in. Once they come in and I install them over the plywood it will look a lot better. Last picture is with the slide all the way in.
JimMartin
Lower bunk:
JimMartin
There were a lot of screw holes in the white wall paneling in the lower bunk area after In removed all the draws. Finished Oak wall panels are $86 a piece at All-Rite RV parts. So I opted for unfinished 1/8" x 24" x 48" oak panels for $10 a piece at Lowes. Trim them out with unfinished 1" x 4" solid oak (for that wainscoting look). Will stain them to match the RV wood work. Here's some pictures on the wainscoting (sorry poor quality camera and the upper and lower bunks with me a the DW on them. I will trim out the rest on the bunk in oak too.
wainscoting:
Upper bunk:
JimMartin
Got the bed moved over. That gives me about 9" extra inches of floor space.
Moved the cabinets, draws, and closet today too. This area is 20" wide and 74" long. Most of the bunk beds I've seen are 28" x 73", I'm screwing (4) 28" long 2x4's to the wood floor. this will make the area big enough for a 28-30" bunk.
Campinfan
It seems there always these hidden things....keep the photos coming. Good luck!
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
BurbMan
Nice work, keep us posted with pics!
JimMartin
Got water tank moved. I had to reroute the water lines but that wasn't a big deal. Just used some 1/2" push on brass compression fitting.
JimMartin
After removing the rear bed and corner night stand I run into the fresh water tank. In order to move the bed all the way over to the wall I need to also move the water tank over alittle.
