Best way to remove caulking from TT's gel coat...
Caneman8434
Hello, everyone. I've decided to replace my TT's kitchen vent after losing several outside door/flappers that blew off at road speed (yes, I did have the latches thrown).
After removing the old vent,(a poor design compared to my new one)I've got some 7 year old caulk around the hole in the wall. I've peeled/scraped everything off that I could, but I'm still left with some caulk that refuses to let go of the gel coat. I didn't want to scratch/gouge up the gel coat, so I quit and came here, the font of all knowledge pertaining to RVs.
Does anyone know of a foolproof (that's me, my wife tells me; I'm the fool)way to remove old caulking before laying down a new bed of caulk around the perimeter of the new vent?
George & Maureen &
"Mercy" the Australian Terrier
2008 Fun Finder X 189FBR TT
2002 Mazda Tribute FWD V6 SUV - AT w/ Oil Cooler
Draw Tite Class III/IV W/ 800# WD System Hitch
Hidden Hitch Digitrac II Inertia Sensing Brake System
5 REPLIES 5
old_guy
if you get to the point of not getting any more off, just put a large amount of caulk back on and install the vent. it will seal OK and just wipe off any excess caulking with your wet finger.
93Cobra2771
An old school trick of spraying WD-40 on there might do it as well. WD40 works great for old sticker residue. Never tried it on caulk, but it's worth a shot.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
gijoecam
I use a straight razor blade VERY carefully to get the bulk off. Any that remains will come off with the 3M remover real easy.
westend
3M caulk remover, it works great, just give it plenty of time to work and you can wipe the caulk off with a rag.
'03 F-250 4x4 CC
GASMAN6674
They make a commercial caulk remover I have used it in the past with decent results bought it at one of the big boxes. You might also try rubbing alcohol, just test it in a small area first. Good luck
Jim & Debbie England
Do you have Gas? Propane Exceptional Energy
2015 F350 CCLB 6.2L/4:30 Vermilion Red
2020 Cougar 364BHLGone but not forgotten 2012 Ridgeline 34RLT fifth wheel/2012 V27FK V-Cross TT
