โMar-19-2017 06:16 AM
โApr-06-2017 06:19 PM
โMar-27-2017 06:04 AM
โMar-25-2017 04:08 AM
Urthworm_Life wrote:I used multiple coats of different sealers, the final coats being spar varnish. I tend to not use urethanes unless it is paramount to not change the color of the wood. Then, I will use a water based urethane. Yes, the thick urethane poured tops can be cool and adding in fossils sounds like a real interesting idea.
Thanks for the compliment on the welds! What did you use for a finish on the pine? I worry about it being too soft. I thought it would be cool to pour that urethane or whatever it is and get that super deep look. Also thought about using a router to do a dinosaur skeleton and inlay my polished fossil fragments. Then go over the top with the poly. You are so correct on the layout of wiring. What a mess but I tried to keep it as simple as possible.
โMar-24-2017 10:07 AM
โMar-21-2017 01:26 PM
Urthworm_Life wrote:Dunno' what the cursor problem is but it's not surprising as the software to operate the Forum is ancient.
Evidently I don't know how to use this forum. If I move my cursor it will not let me continue.
So yes I will be checking out your build! Thanks again for the compliment as well as the information!!
โMar-21-2017 12:45 PM
โMar-21-2017 12:43 PM
โMar-21-2017 08:16 AM
โMar-21-2017 07:03 AM
โMar-20-2017 07:23 AM
โMar-19-2017 06:34 AM
โMar-19-2017 06:22 AM
Cap'n Black wrote:
I believe I selected the correct category for this build. I just wanted to share what I am creating. I will also need some advise along the road so I wanted to get started here. You can also follow this build on Facebook, Instagram, and youtube under Urthworm_Life.
Comments and advise are most welcome.
https://youtu.be/C8xd66LG1NM
โMar-19-2017 06:21 AM
โMar-19-2017 06:20 AM
