Help me find this bracket.....
js415
I have searched and searched, and maybe I'm looking in the wrong places.
I need two of these brackets like I have pictured below.
Anybody have any idea what they are called or where I can find a pair?
Thanks,
Jerry
11 REPLIES 11
js415
Thanks for all the suggestions and helpful hints.
I found what I was looking for when I started searching for "Keyhole Brackets".
This particular bracket is what is used on my daughters pop-up to hold a small gas stove onto the side of her trailer, for use outside.
She never uses the stove, so I thought I could find a couple of brackets and make her a small table to mount in the same location.
If I can find some proper materials for use as a tabletop, then I believe I can get something worked up for her.
Thanks again for all the help and ideas.
Jerry
Tin_Pusher
Here ya go: Furniture Clip
Tin Pusher's Guide To Successful RV'ing: "Don't get mad, don't get in a hurry"
2002 1500HD
2002 Wilderness 265H
1997 Seadoo GTI
1952 Wife;)
mobeewan
Do they have to be exactly the same or would something like this work?
blownstang01
What hooks to, or "latches" to it ? If it is some sort of lock mechanism, it's usually easier to get a manufacture name off the lock/latch and search or call them for the latch plates they carry.
Homeless_by_Cho
I had those exact brackets on the ends of the cross brace under my dining table. The cross brace was milled out to cover/hide the hardware. There were two brackets on each end to keep the cross member from rotating and making it very strong.
I believe it is called a HANGER PLATE. Ref Click Here to view a similar one
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
JoeH
What's it used on/for ?
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Blacklane
I found a lot of similar brackets by doing an internet search (specifically Google image search) on "Bracket Keyhole".
I did not see your bracket, though.
falconman
They look similar to whatโ€™s called a โ€œfootman loopโ€. Theyโ€™re not exactly the same but it might get you started.
SidecarFlip
BarneyS wrote:
I think I would send an e-mail or call this place and send a picture like you posted here. I bet they can tell you what it is called, where to purchase that bracket, or they can make it for you.
Good luck.
Barney
You footing the bill on the call?
They are in the UK.
I'd peruse the Mc Master-Carr online catalog. Bet it's in there somewhere.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Ava
That looks like it would be easy to make one up yourself if you have some basic tools, drill and pliers or vise.
BarneyS
Good luck.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
