โMar-31-2021 08:39 AM
โOct-06-2021 06:26 AM
โOct-05-2021 06:54 PM
โOct-05-2021 06:02 PM
โOct-05-2021 04:10 PM
โOct-04-2021 08:46 PM
โOct-02-2021 07:33 PM
โOct-02-2021 07:13 PM
โOct-02-2021 05:40 PM
โSep-28-2021 06:11 PM
โSep-28-2021 06:57 AM
time2roll wrote:
I plan on minimal compression with two zip-ties around the box. The straps are temporary to hold the cells in place to fit the bus bars. If using ratchet straps I would re-thread them to eliminate the hooks.
time2roll wrote:
I decided to skip the separators. They are wrapped nicely in the standard blue vinyl. Easy to overthink everything. Have not really read any issues with skipping the separators even though some insist something is needed. Not intended to be a bulletproof off-pavement design.
time2roll wrote:
The box wall next to the fuses is floating (movable). There will also be heat pads, one per cell, on the outside controlled with a thermostat. They are 15w silicone pads. I will run two in series for maybe 4 watts each, 64 watts for the entire block.
Member Pianotuna will be pleased to see my battery wiring will finally get balanced ๐
โSep-27-2021 06:21 PM
โSep-27-2021 09:11 AM
โSep-27-2021 08:19 AM
time2roll wrote:
I put the 2x Overkill BMS and some fuses on a small shelf in the box. This is actually two separate batteries. Each has 2 cells in parallel and 4 in series so 8 cells per battery.
I expect to get this into my front compartment next weekend.
โSep-27-2021 08:14 AM
FWC wrote:otrfun wrote:
Overkill BMS's seem to have a very good rep; however, to my knowledge they don't make BMS's larger than 120a. For those who have 2000-3000w inverters with 200-300a current requirements what options do they have? Daly makes a few 150-250a models, but they have a somewhat sketchy rep. I suppose one could parallel multiple Overkill 100-120a BMS's and LifePo4 battery packs.
Running several in parallel is not a bad idea, it would be the same as running several drop in batteries in parallel. It spreads the load (and heat) across multiple devices, and provides redundancy as well. On the down side, you would need to look at several screens on the app to see what each pack is doing, but that is not a huge deal. If you are handy you could also merge the data from each BMS into one stream as the protocol is open source.
To give credit where credit is due - these are not Overkill Solar's BMS, they are just retailing/rebranding LLT powers BMS.
โSep-26-2021 03:31 PM
