Installing a Tip-out Pop-Out Tent in cargo trailer?
rerod
Iv always liked these Tip-out Pop-Out Tents and wondered how difficult it would be to install one in a older enclosed featherlite 4926 cargo trailer? I know once you cut the opening you would have to weld in horizontal aluminum headers.. So, would you have to remove the exterior aluminum skin (very difficult) , or be able to pry the skin away enough to cut the studs shorter and weld in the header? I cant imagine being able to weld the backside of the header with the skin in the way.
Thanks!
http://www.united-trailers.com/Pop-Out-Tent
http://www.fthr.com/products/car-trailers/bumper-pull/4926-car-trailer
12 valve ram
4 REPLIES 4
DutchmenSport
rerod, I think your plan will work. If you are able to put a solid, hefty header on top and bottom, I see no reason why you could not make it work. Pretty novel idea you've got going on there. I've never seen this before. Pretty cool! Thanks!
rerod
Home Skillet wrote:
Spendy.
LINK
Thanks.. $1,699.99 Wow!!
The instructions don't mention anything about cutting studs and adding headers, so Ill assume this Bed Door Fold-out Tent is intended for new construction or while the camper is still in the design phase..
12 valve ram
Home_Skillet
Spendy.
LINK
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
RoyB
Thats a pretty neat idea to me...
On the inside this only takes up about a foot of space it appears...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
