Installing an Inverter
deltabravo
Last fall I installed an inverter in my rig.
It was a pretty involved process with a lot of prep and planning required because I had to relocate a few things, build a small platform for the inverter and also switch to a shorter range (stove / oven)
I broke the project up in to several videos, starting with showing tools I use for the battery cables and how I built them:
Temco TH0005 Hydraulic Crimper
Building the battery cables
Part 1: Project Planning
Part 2: Battery tray, shunt and fuse mounting
Part 3: AC and DC Wiring
Installing the new Range
Project completion: Color Control GX remote and BMV-712 Battery Monitor
3 REPLIES 3
deltabravo
2oldman wrote:
Which video shows the actual inverter?
This one
deltabravo
2oldman wrote:
Your second link doesn't work.
Fixed it
2oldman
Your second link doesn't work. Which video shows the actual inverter?
