โJan-08-2014 06:17 AM
โJan-10-2014 08:16 AM
โJan-08-2014 04:36 PM
โJan-08-2014 04:02 PM
jmtandem wrote:
Iowa Cowgirl,
All is not lost! Horse trailers with living quarters will outlast virtually any RV with the possible exception of an Airstream. The horse trailer is made with axles that are up to the job, tires with weight ratings that are realistic, no filon sidewall delamination possible, no rubber cheap roof that only lasts 12 years, etc. In the long run you have a superior RV that in the short run needs a few minor things fixed inside. That is way better than a new standard white box that will need lots of things fixed on the outside as it ages and that came with barely able axles and tires. Keep your chin up and I am sure the electrical issues will be solved to your satisfaction very soon.
If I was looking for a toyhauler that would go the distance, I certainly would have on my short list a living quarters horse trailer.
โJan-08-2014 03:38 PM
โJan-08-2014 01:24 PM
Kinda/sorta.
There is no transfer switch.
Right now I plug the fridge into an outlet that is under seating. The outlet is somehow rigged to the inverter. I flip the inverter "on" and I'm running on 12v.
When I get to the campground, I unplug my fridge from the outlet under the seat, flip the inverter switch to "off" and plug the 30 amp shore cord to the shore power.
The inverter is not in play at all when I'm camping.
FYI: I don't do shows or fair. I camp with my horses and trail ride. Now that's bringing a pet along! lol
โJan-08-2014 12:50 PM
โJan-08-2014 12:33 PM
I paid a LQ conversion guy to build my conversion.
โJan-08-2014 12:25 PM
That seems pretty clear to me... but I guess the YES!!! is for running off 12v, which I previously said was confusing and she didn't correct me.
Before any problems can be dealt with we have to know what exactly they are. I have never heard of using a transfer switch for batteries and 110.
โJan-08-2014 12:01 PM
โJan-08-2014 11:55 AM
Iowa Cowgirl wrote:
The first guy came highly recommended by a horse trailer dealer, so I didn't worry or check references. Bad on me. I'm taking him to court, which is out of state.
Not asking for pity. It just sucks.
โJan-08-2014 11:50 AM
โJan-08-2014 11:46 AM
โJan-08-2014 11:39 AM
โJan-08-2014 11:36 AM
MrWizard wrote:
Cowgirl
Correct me if I'm wrong
Right now you plug the fridge into a socket/ cord powered by the inverter
When you reach the show/fairgrounds you move the fridge plug to another OUTLET for the shore power
Assuming both are located near the fridge, you simply plug the fridge into the transfer switch output, and plug the two inputs into the two power sources
One into shore outlet one into inverter power
One input is default "inverter" the other is the "switched" shore power
It switched automatically when you plug in the trailers shore chord
