Night Stand Shelf Wardrobe Cabinet Mod
houstonstroker
So our Queen bed is in our rear slide. No night stands on either side. Nowhere for DW to put bottle of water, reading glasses or wine glass. DW's side of the bed was right next to her wardrobe. So we made a shelf, cut a hole in the side of the wardrobe and sunk a shelf in the opening. She lost a little room in the closet but still enough room to hang shirts on the side over the new recessed shelf.
The finished product
2016 Dynamax Force HD Super C
25 REPLIES 25
houstonstroker
8 inches is the interior height. Standard water bottle or small wine glass. For a bigger glass she might have to use stemless.
wannavolunteerF
did you height check for her wine glasses? beautiful job, I always wonder why manufacturers don't put in side tables that are usable.
2015 FR Georgetown 378TS
3oaks
Oldme wrote:
Great project.
Now that is a great idea.
Yes. Well done.
Oldme
Great project.
houstonstroker
The wardrobe has two thin panels with a 1 inch hollow space. I'm sure you are shocked but no studs anywhere. We cut 1 inch boards and framed the opening before the shelf was inserted. Used sealant adhesive around the lip. Will check tomorrow when it dries and see how solid it is.
DrewE
I agree, very nicely done. Thanks for sharing.
bugs53 wrote:
Terrific Job. From an old Trim Carpenter.
Now get some matching paneling (from your local building supply), cut the four sides and back to fit, turn the cut inserts to match the grain of the wood, but come corner molded trim pieces for the inside cuts, and wah-lah it will look like it came from the factory that way.
Well done. 🙂
Bugs53
If it's built like my RV, you'd also need to drive a coupe of pin nails or staples that don't quite hit the framing and leave a slight or gap or two at the panel corners... 😉
bugs53
Well done. 🙂
Bugs53
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
Wiscampsin
Great idea and a job well done.
Bumpyroad
well done. I have seen several RVs built like that.
bumpy
BTPO1
Nice idea, got me to thinking about doing the same.
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
Artum_Snowbird
Now that is clever, thanks for the idea.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
