Oxygenics RV Shower install: A problem
kyonu
Okay, so I went to install the Oxygenics shower head and ran into an issue. It connects just fine, but when I turn on the water, it gets stopped at the base of the hose connecting to the shut off valve. I have attached a picture for a better visual. What would cause this? It appears the connection on the inside of the rubber isn't tight enough or something, as I can pull down on it and it cuts the water flow and forces it out of the shower head. What am I missing?!
26 REPLIES 26
Johno02
Go back to your trash can and take another look in the packageing. The washers were probably loose in the package.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
John_Wayne
Maybe you have two washers stuck to the old one check.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
ChooChooMan74
kyonu wrote:
Well crap, looks like my unit did not come with washers. ๐Ÿ˜ž Off to the Depot to pick some up.
Looks like yours was put together at 4:59 on Friday....
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
kyonu
turbojimmy
You need a washer at both ends:
1984 Allegro M-31 (Dead Metal)
ronfisherman
Moderator
Moderator
Your missing 2 washers.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
kyonu
That's what I thought, it was missing a washer or something... But then I saw these:
turbojimmy
nomad297 wrote:
It's missing the rubber washer.
Bruce
x2
Johno02
Sounds like to gasket is missing.
youngone
Was there a black rubber washer where you hook up the hose to the shower head?
copeland343
Check for a gasket. Also try switching the hose ends around, the ends might be just a little different enough to work. I know they should be the same but quality parts are hard to find.
nomad297
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
