Renogy batteries and charging
Groover
I am thinking about putting Renogy lithium-iron batteries in by RV but Renogy sales tells me that I need a charger made specifically for that type of battery. I currently have a Magnum ME2012 charger/inverter that has lots of adjustments but nothing that specifically says lithium. I tried every way that I can think of to contact Magnum about an upgrade with no success. So I am asking here. Does anyone here use a Magnum charger with lithium-iron batteries and how is it working out for you?
17 REPLIES 17
Itinerant1
Something else to think about the ability to view individual cell voltage incase one was starting to drift, even with cell balancing. Bluetooth app or hardwired.
Any programmable charger will work with lfp batteries.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,500+ partial cycles.
Groover
I just came across this recent comparison of lithium batteries on youtube. I have seen Renogy batteries on sale for $800 each direct from Renogy but have never seen Battleborn batteries for less than the asking price of $949. Before I purchase I will compare prices at the time. Based on what I would know now I would pay $50 more for the Battleborn but probably not $150.
Lithium battery comparison
Battleborn seems to have put together some better charging information:
Battleborn charging
They even have specific instructions for my charger:
Magnum charger settings
Groover
Almot wrote:
Groover wrote:
This is what is in the manual on-line: "• Standard Charge shall consist of charging at 0.2C constant current rate until the battery reaches 14.6V.
The battery shall then be charged at a constant voltage of 14.6V while tapering the charge current.
Charging will terminate when the charging current has tapered to a 0.02CA."
Make sure this is a manual for your particular battery. Since Renogy is in batteries business now, God knows what other batteries they might sell.
Applying charging current after full charge is not very common with Li. In fact, applying any current after 90-95% of full charge is not a good idea with Li, the detail that manufacturers prefer not to mention. Get a charging graph V vs SOC% for your battery and stay within 30-90%. 40-50% while in prolonged storage.
That came from their online manual for the battery. It seems to call for limiting amperage until full voltage is reached then limiting voltage from that point on. I called Renogy a few days after posting that and the tech guy I talked with acted like he had never heard of the .2C limit and thought that the 50amp charging limit was more realistic.
My next question if I do this is how to handle the battery isolator that charges the house batteries when the main engine is running. My alternator produces 14.1V. It appears that I am going to have see what the lithium battery voltage does when the Magnum charger is turned off. If it drops rapidly to or below 14.1 there won't be an issue. If the batteries try to stay above 14.1 they could run themselves down backfeeding into the chassis circuit. That shouldn't be too hard to figure out. The worst case would be that I disable the house battery charging from the alternator until the voltage drops.
Almot
allen8106
Groover wrote:
drsteve wrote:
Ask Renogy for the specific requirements for charging their batteries.
Also the desulferizing routine would need to be disabled. With those batteries setting me back about $3,300 I don't want to do too much trial and error.
With the Magnum inverter and the ME-RC50 the de-sulfication routine is a manual operation by holding the charge button down for like 3 seconds while in float mode.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
When used with the Magnum ME-RC50 you can use custom charge settings that will charge the lithium batteries correctly.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
pianotuna
Nomad III
Nomad III
Hi Groover,
Thanks for letting us know.
Regards, Don
Groover
The Magnum charger has a custom setting and it looks like all that I need to do is put it on the custom setting, set it 14.6V and disable the desulferizing routine. Just in case anybody is wondering.
2oldman
Other specs I find on Renogy site say you can charge at up to .50 C (50amps), so I don't understand the .2 thing. With 4 at 80 that's probably all you can throw at them anyway. I can charge my pack at equivalent 136 amps.
Lwiddis wrote:
But 2oldman won’t that void the battery warranty?
I don't know.. haven't read it.
Groover
Charging will terminate when the charging current has tapered to a 0.02CA. Charge Time is approximately
7 hours. Safe Charging consists of temperatures between 32 ºF and 113 ºF."
It sounds like with four 100ahr batteries I could charge at 80amps up to 14.6V then try to hold 14.6V until fully charged. I will have to play with the Magnum unit to see if it will let me do that. Also the desulferizing routine would need to be disabled. With those batteries setting me back about $3,300 I don't want to do too much trial and error.
Groover
pianotuna wrote:
LI in general, do not prefer a float charge.
I see Renogy is offering a 170 amp-hour 12 volt battery.
Interestingly the cost per kwh is less for the 100ahr battery than it is for the 170ahr. However, the maximum current is about the same. I guess that is due to the cell protection circuits. I figured that 4 100ahr batteries would be better than 2 or 3 of the bigger ones so that I would be less likely to exceed the rated discharge rate plus my coach is set up for 4 medium size batteries already.
Groover
pianotuna wrote:
https://www.magnum-dimensions.com/mobile-power-products
and to email or phone them:
https://www.magnum-dimensions.com/contact-power-conversion-solutions-team
I have used the email on the Magnum page 2 weeks ago and called every number on the page with no response yet. A couple of days ago I spent an hour on hold and advanced from #3 in line to #2.
pianotuna
Nomad III
Nomad III
Regards, Don
pianotuna
Nomad III
Nomad III
Regards, Don
