May-03-2018 04:41 PM
May-04-2018 08:25 AM
phemens wrote:
Better if all batteries feed to bussbar with equal length cables on pos and neg.
For the combined inverter charger deals, I’m more a fan of keeping the components separate. If one part fails you are stuck replacing the entire unit. Also easier to troubleshoot if you have an issue. I am a big fan of the Victron monitors and Bluetooth app!
May-04-2018 07:28 AM
May-03-2018 09:47 PM
Rbertalotto wrote:
Balance batteries.....I thought you would connect positive to positive and negative to negative and then take positive from top battery and negative from bottom battery
May-03-2018 09:13 PM
May-03-2018 08:40 PM
time2roll wrote:ependydad wrote:That is not back feeding. Back feeding generally involves a cord with a male plug at each end. aka dead man's cord or suicide cord.
get rid of the hokey extension cord + backfeeding of camper
Plan looks generally good.
I agree on larger inverter, say 2000 watts, to run any large item that plugs into a normal outlet. (one at a time) Microwave can draw 170 amps BTW. Maybe a little less amps on lithium as voltage sag should be less.
Your transfer switches may need some work. You need switches rated for the full generator power. As shown the generator power goes through a 15 amp switch. Are there two breakers on the generator? What is the rating(s)?
Also the inverter needs to be wired so it does not feed the converter. You can put the 15 amp transfer switches on the branch circuits (outlets only) or do the subpanel to break out inverter vs non-inverter circuits.
May-03-2018 08:19 PM
May-03-2018 08:17 PM
phemens wrote:
How far is the inverter from the battery bank? That will dictate the gauge you should use. For reference, my 2000w inverter is about 3 feet from my bank, and I use 0000. I use 00 to interconnect everything else.
May-03-2018 08:16 PM
pianotuna wrote:
Your bank is not balanced.
Have a look here:
http://www.smartgauge.co.uk/batt_con.html
I use method #3
May-03-2018 08:05 PM
pianotuna wrote:Diagram shows equal length wire to a bus bar. Looks balanced to me.
May-03-2018 06:59 PM
May-03-2018 05:07 PM
May-03-2018 04:54 PM
