I have a spot on mine that had been gooped with silicone, since the eternabond doesn't stick well. Where the roof meets the front cap. I've pulled on the loosened Eternabond, until I find a part that doesn't want to pull up, then cut it there, reclean it with the Eternabond cleaner, then retape overlapping the previous. That seems to stick ok, but the spot where the big clump of silicon was may need another treatment with silicone remover if it comes loose again. If the top cover of the tape came apart, I would be tempted to tape over it after cleaning it. Worst case is that the original tape will be the same amount of trouble to pull up, assuming it is still sticking well.
Coachmen Pursuit 31BDP 2013, 300w solar, 1200w sine inverter, In-motion Winegard Dome sat. ant., L.E.D. lights, P2 brake controller, Yamaha 250 on back carrier, or pulling Stehl dolly with Hyundai Santa Fe
