โAug-08-2014 09:43 PM
โAug-10-2014 08:43 PM
larry barnhart wrote:
... but I know the answer is "because we can" that is ok as I agree .
chevman
โAug-10-2014 02:01 PM
Carb Cleaner wrote:
My tires and wheels have been upgraded, too. I didn't order Ford's 18" wheels (which may have increased my Carrying Capacity Rating on the yellow sticker) because I was able to get the exact wheels and tires I wanted for a few bucks more.
โAug-10-2014 01:47 PM
โAug-10-2014 08:58 AM
โAug-10-2014 08:41 AM
Carb Cleaner wrote:Cummins12V98 wrote:
'13 F250 4x4 with camper package, 10,000# GVWR
I don't get it. A new truck and you have to modify it to do what you want. Why not just get the 350 to begin with?
That's a fair question.
Short answer: I make it up as I go along.
Long answer:
I spec'ed the truck for towing a 5th wheel. The specs are/were higher, towing capacity wise, for the F250 than the F350. Our truck camper came about from changing directions in mid-stream. Many with an F350 SRW perform the same mods. The sag doesn't bother me, my truck sits about level with nothing in the holding tanks, it's the swaying I'm trying to subdue. I'm not really trying to compensate for weight on a hitch, it's the top-heavy nature of a truck camper that can be unnerving.
My tires and wheels have been upgraded, too. I didn't order Ford's 18" wheels (which may have increased my Carrying Capacity Rating on the yellow sticker) because I was able to get the exact wheels and tires I wanted for a few bucks more. In Virginia, it's registered for 12,000 pounds.
Drive-shaft spline count, 2" thicker rear axle block and an extra leaf spring are the differences between a F250 and F350. The Camper Package gives a F250 the extra spring and front/rear sway bars. I'll take my chances with the spline count and I can get F350 axle blocks from the junk yard all day long (new, longer U-clamps would be required).
โAug-09-2014 07:32 PM
โAug-09-2014 10:38 AM
โAug-09-2014 08:12 AM
