Underbay Storage Slideout - need design
FontanaHorseman
I have seen somewhere a design to add a sliding tray in an storage compartment somewhere.
Adding under a 5th wheel - one side of the pass thru. Needs to be
1 & 1/4" to clear door bottom and probably about 20" wide.
Just want to add a flat sheet of plywood w 1/4 round edging to hold several tubs on it. Will need to extend about 4 feet outside trailer. Tubs weigh about 30lbs each...holding 30 ft 50amp elec wire, plumbing hookups, other junk.
If someone can point me in the right direction or give me any designs I would love it!
Thanks, FH
04 Ford F250 CC, 6.0L PSD
2018 Keystone Sprinter 298FWRLS
Wild, Wild Wife, 3 wild grown kids (22, 21, 20)
Husband running from little men in White Coats!
The only thing necessary for the triumph of Evil is for good men to do nothing.
Edmund Burke
8 REPLIES 8
MrWizard
Moderator
Moderator
I have done several small cargo slides for portable generators, done In one day start to finish, would be even less time, if I wasn't so slow, for me what should be 3 to 4 hours, turns into an all day job
I can explain it to you.
1997 F53 Bounder 36s
Veebyes
Have a factory installed one in my 5er. Wonderful having the thing. Don't know the cost. It was a standard item for the model.
I would imagine the aftermarket purchase would not be cheap. Course buying readymade is no labour on the owners part. Who knows how many hours for a DIY?
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
agesilaus
ferndaleflyer wrote:
Just buy the ready made ones. I have 2 in my Monaco but not cheap.
Yeah $1400 for my pass thru was the quote. I can make one for maybe $300
For those thinking about it, I found this video very useful. Anything he uses the table saw on you can do with a hand circular saw or even saber saw and a guide. Wood magazine
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
MrWizard
Moderator
Moderator
44 inch long time heavy duty slides
Full extension,
44 inch cargo slides
For more ideas Joey Bed RV Cargo Slides
jdc1
You're looking at $200+ for full extension heavy duty drawer guides.....
agesilaus
I don't know about designs but that project is on the far back burner for my RV. You need a couple of ball bearing slides, preferably full extension, that are as long as the compartment is deep. Amazon Or less than that if that's what you desire. And I plan on using that hardwood plywood that the big box stores are selling now.
And then misc wood to mount the slides in the compartment and make the plywood shelf. You will loose some of the width and height of the compartment to fit the slides in. Keep in mind how heavy those totes will be in total when buying the slides. I'd use at least 1/2in plywood.You can use the cheaper stuff and just give it several coats of paint.
These YT videos might give you some ideas
Superbumper
gbopp
Did you check YOUTUBE?
