where does this hose connect ?
scottyboy28422
just finishing our new home built RV . salvaged a nice 2011 zinger for parts. got a white flexible line on water pump that I don't know where it goes. see pic if it goes thru
2 REPLIES 2
Admin
Moderator
Moderator
Double post
See other thread running here.
Thanks
Admin
RV.net
Admin
RV.net
lawrosa
Pic did not go through. Most lines from the pump are uses to suck up antifreeze for winterization or even filling the water holding tank by using the pump.. Need to shut off or open certain valves.... etc..
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
