110 PSI Air While on the Road
otrfun
Thinking about upgrading from 80 PSI E-rated tires to 110 PSI G-rated tires.
I assume 110 PSI air is available at most Love, Pilot-type truck stops?
Anybody use a portable air compressor? If so, what make/model?
66 REPLIES 66
TXiceman
I carry a 150 psig air compressor.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
CA_Traveler
And the psi should be set based on the axle weight and load inflation tables.
2014 Grand Cherokee Overland
Bob
Big_Katuna
Check your rims for max rating too. Most are stamped 80 PSI max.
My Kharma ran over my Dogma.
darsben1
I carry a cheapo Harbor Freight pancake compressor.
I plan to use it only if necessary.
Usually I stop at a tire store and have them check the air pressure in the tires every couple of weeks when I am on the road. Slip the guy $5.00 for his trouble and good to go. I have used the air hose at a couple of truck stops and always found the pressure adequate. The coin operated ones are not good for me as the volume is to low. Prefer a tire shop BIG "O" is great about doing this
Traveling with my best friend, my wife in a 1990 Southwind
Sam_Spade
Just because the "tougher" tires you are buying allow for pressures up to 110 lbs does NOT mean that you should put that much in them.
In fact, you probably should NOT DO THAT and use close to the original recommended pressures if the load has not changed.
I personally think that getting good name brand tires is more important that putting on ones that are WAY over-rated for your application.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
b17drvr
Most places have 110 + psi air.
I got this compressor on Amazon:
PORTER-CABLE CMB15 150 PSI 1.5 Gallon Oil-Free Fully Shrouded Compressor
It is light and works great.
2oldman
tons of posts on 'air compressor'
