Aug-18-2019 10:06 AM
Aug-19-2019 10:39 AM
PNW_Steve wrote:If you have a factory 7-pin trailer connector then you have the feature.
Now I am curious....
I am aware of the designation of one of the pins on the 7 pin connector is 12v supply.
I assumed that it was not used as none of the truck/trailer combos that I have owned have charged the trailer from the truck charging system.
How common is it to have that feature from the factory?
Aug-19-2019 10:27 AM
Bud
USAF Retired
Pace Arrow
Aug-19-2019 09:20 AM
Aug-19-2019 09:10 AM
Bud
USAF Retired
Pace Arrow
Terryallan wrote:tersct wrote:
My 5th wheel does not power off of my vehicle when connected to it. A couple of times after it has set for a period of time, with no power connected to it, the 12V battery needs an assist to get the front jacks to raise for movement. This usually happens when I leave it at a dealership for repair work. When this happens they have had to use a battery pack (?) to raise the jacks. Who can tell me what type of pack they are using? Is it just a rechargeable battery pack or is it something else? Thanks.
What vehicle do toy tow with. "Most" need a relay installed to charge the trailer. and then will only charge the trailer when the ignition switch is on / motor running.
Aug-19-2019 09:08 AM
Aug-19-2019 08:31 AM
Aug-18-2019 03:17 PM
Aug-18-2019 03:07 PM
Aug-18-2019 02:36 PM
Aug-18-2019 12:04 PM
Aug-18-2019 11:00 AM
Aug-18-2019 10:57 AM
Aug-18-2019 10:31 AM
Bud
USAF Retired
Pace Arrow
